Community
Search
99 Jimmy Wont start
Old 01-08-2016, 07:49 PM
litlmeal is on a distinguished road
Angry 99 Jimmy Wont start
I just bought a 99 gmc jimmy with 146,000 that the previous owner said he was driving along and it just died. It cranks over good but backfires thru the intake and then cranks hard for a second. Has no codes in ecm. Guy before me replaced plugs,wires, distributor, and cranks sensor, I replaced fuel filter, checked timing on distributor and distributor turn when turning engine over by hand, checked fuel pressure(good has 60psi and holds between 60 and 55 for good amount of time) and fuel pump runs good, seems to have good spark when using inline spark tester, swapped ecm with one from my blazer and coil and icm,cleaned iac valve as it was dirty. have not found any blown fuses. i Have even tried a different battery as the one that came with vehicle is getting a little weak.I am hoping someone had some ideas on what to do next or what may be the issue or have had the same problem in past. Would it have to do with possible timing chain jumping teeth and is there any way to tell if it chain has jumped without tearing down to timing chain?
Old 01-09-2016, 06:53 AM
canuck blazer is on a distinguished road
have you put a code reader on it? see if any codes present and post them
Old 01-09-2016, 08:01 AM
Captain Hook has a spectacular aura aboutCaptain Hook has a spectacular aura aboutCaptain Hook has a spectacular aura about
Distributor cap & rotor need to be AC Delco. Aftermarket stuff doesn't cut it on these engines. Very likely that is the problem.
If the crankshaft position sensor or timing cover is moved, removed, replaced, or disturbed in any way, the crankshaft position sensor relearn must be performed, (requires a scan tool capable of initiating the relearn). Same holds true with the PCM.
Extremely doubtful the timing chain jumped. There is a way to check it without any engine disassembly though.
Start with the distributor cap & rotor. Make sure you put silicone dielectric grease on all terminals, inside and out. Post your results.
Old 01-09-2016, 08:23 AM
Nope no code and no check engine light
Old 01-09-2016, 08:34 AM
Ok i will throw a cap and rotor on it im pretty sure they are aftermarket brand
Old 01-11-2016, 05:19 PM
Ok had to order cap and rotor. Installed new ac delco cap and rotor. Engine cranks over faster and attempts to start then i hear a loud knock and starter then has a hard time turning engine over at that time.possible bent or broken valve?
Old 01-11-2016, 07:35 PM
Double check the spark plug wiring.
Pay close attention to cylinders 1 & 3
on the distributor cap.
If that checks out ok, unplug the electrical
connector from the ignition module and
try to start it. See if it knocks or there is
a hard time turning the engine over.
Old 01-11-2016, 09:31 PM
Ok checked plug wiring all looks good.unplugged ignition module and it turns over great and no more nock
Old 01-12-2016, 02:50 PM
Unplugging the ignition module disables the ignition: If the engine turns over fine, with no knock, it tells us the no-start and knock noise are ignition related. If you're absolutely sure the plug wires are correctly routed, the next thing to check, is the rotor. The under side of the rotor was designed so that it can only be installed one way. Unfortunately, it IS possible to install it 180 degrees out of phase. If this happens, the starter will "fight" the ignition, and the engine will not start.
The knock sound you're hearing, is actually a cylinder firing with both valves closed, which makes it very difficult for the starter to continue cranking the engine.
Old 01-12-2016, 03:41 PM
Ok i will check that i do have to ask to make sure i did the dist. Timing correct. Turn engine over till cyl. 1 is on tdc conpression and install dist. So that when it fully seats the rotor point is aiming at or very close to the little imprinted 6 on the dist. Housing?
Is that all correct?
Quick Reply: 99 Jimmy Wont start
