99' key lock cylinder replacement
Old Jul 13, 2014 | 07:01 PM
Tuna's Avatar
Tuna is on a distinguished road
Default 99' key lock cylinder replacement
Does one have to remove the steering wheel assembly to replace the lock cylinder on a 1999 Blazer 4 door LS?
Following a video on servicing the multi-function switch to stop the constant clicking of the relay, it instructed one to pry off the vinyl key cover. The video was pretty correct up to that point, but attempting to do so actually snapped it from the cylinder. Apparently, the video was for another model year. I did resolve the clicking problem though simply by cleaning the contacts with Q Tips and electrical cleaner.
I am attempting to glue it on, but success is not likely. So if I have to replace it, what problems will I encounter. I do not relish taking the whole thing apart again or removing the steering wheel, as I do not have the pullers for that job.
I recall replacing the lock cylinder on a Ford F350, and all that required was a nail and about 5 minutes. I am sure GM does not have such an elegant solution.
Does anyone have the "key" to my Problem?
Old Jul 15, 2014 | 10:47 AM
Tuna's Avatar
Default No answers??
No one seems to have responded to my questions regarding the key-lock cylinder problem. I doubt that all the brain power of this forum has found this too challenging, so I expect the post just slipped through the cracks.
As I expected, the glue did not work to secure the vinyl lock cover to the cylinder. What's the next step, guys/gals??
Thanks much!
Old Mar 26, 2022 | 02:32 PM
Leighann's Avatar
Leighann is on a distinguished road
Default Second stuck ignition cylinder
Thanks much!
Hi Tuna, thank you for your questions and answers, I'm sorry no one responded to you. So I have a99 blazer ls list my keys so I replaced the ignition cylinder. After drilling the old one out I went to put the new one in and the entire cylinder shifted forward and is stuck past the on position. It is not locked and the key is stuck in it. Any ideas?
Alex Eberhart
May 12, 2019 08:48 PM
popeyz
Dec 27, 2014 03:11 PM
Tuna
Jul 20, 2014 06:45 PM
fixer34
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Dec 17, 2010 03:12 PM
MetalMan390
Jun 8, 2010 02:27 PM
