?? about part
The hose from the pcv valve broke, was cold today and it was brittle, didnt realize I needed an elbow but got another hose for a temp fix, noticed that there are no clips holding the top of something down, it just pulls out and has a big O-ring around it, it has been staying in place but would like to get it fixed, what would I need to get it fixed looked on oreilly and it shows the elbow that I need and a pcv valve but nothing else, what is that called where the pcv valve hose goes into??
Do you have a picture? The PCV valve plugs into the valve cover and as best I can remember, there is no retainer. There is a seal in the valve cover and the PCV valve pushes into that seal.
Maybe you are refering to another area? |
no pic, picture the pcv valve in the valve cover, there is a short hose off the pcv valve then a hard plastic molded line, then on the end of the molded line there is a pcv elbow and it goes down into this part on the motor, i am trying to look for a picture and searching, its where the pcv valve connects to at the other end
Take a look at this and is it item number 20? If it is, that is called a PCV Cover. If I recall from the work I did last year on my intake manifold, that part gets retained by being rotated into a locking position. There are no bolt down clips. That is my recollection. Here is the Part Number (12552750 which is supposed to include teh seal as well.) I think the retaining tabs are part of the upper manifold (Black plastic part). Someone else may be able to confirm.
http://i813.photobucket.com/albums/z...t/SCAN0007.jpg |
Yes, thank you so much.. it is #20, well i had to pull the hose back off and since it was tight, I think I may have broke the rotating clips that hold it, I am going to go back to oreilly tmr and get the pcv elbow, it was cracked and broke and thought i could get a hose in there but its to tight of a bend
