ABS Help
Old Mar 5, 2013 | 10:55 PM
kajida's Avatar
kajida is on a distinguished road
Default ABS Help
Hey all,
So my ABS started kicking on for no reason a few weeks ago, and then the ABS lights would come on and I would have no ABS at all. At first I figured it was bad speed sensors, so I replaced those. The problem went away for a couple of days, but returned and was even worse. My ABS would go off almost anytime I hit the brakes when under 5mph, but never above 5mph. So scaned the codes again and it said speed sensor issues... So a mechanic friend of mine kinda poked around and said my hubs were shot. So we replaced both front hubs today (and they both came with new speed sensors) and WOW what a difference! My truck is soooo quiet inside when above 35mph now, it's amazing! Looking at the old hubs, the bearings were totally shot. It's amazing the difference in vehicle noise now... BUT guess what, my ABS light is still coming on, and the codes are still saying Speed Sensor issues... So, where should I look now? ECM?
Thanks
Old Mar 6, 2013 | 04:51 AM
newguy's Avatar
Try something cheap first, disconnect the battery for 20 mins or so, may reset it
Old Mar 6, 2013 | 07:17 AM
richphotos's Avatar
is the speed sensor adjusted correctly?
Old Mar 6, 2013 | 08:29 AM
kajida's Avatar
@ richphotos, I didn't know there was a way to adjust them. They were already installed in the hub when we swapped the hubs yesterday, so I assumed everything was correct. What's the way to adjust them correctly?
Old Mar 6, 2013 | 09:02 AM
newguy's Avatar
I dont believe there`s an adjustment
Old Mar 6, 2013 | 11:42 AM
kajida's Avatar
Yeah, I didn't think there was either. I know there's a shim that goes in between the hub and the sensor, but other then that, I couldn't see how it could be adjusted.
Tinted
Mar 15, 2012 02:56 PM
iamchevyman5
Feb 28, 2011 04:35 PM
92K5BLAZER
Jan 20, 2010 02:52 PM
stormshadow1
Apr 23, 2009 09:46 AM
evancanada
Oct 20, 2006 09:00 PM
