Abs issue
Old Aug 14, 2013 | 04:37 PM
nitromt's Avatar
nitromt is on a distinguished road
Default Abs issue
Got a 99 jimmy been having an issue with the abs engaging when coming to a stop and turning doesn't do it when im driving straight. So today i replaced the front passenger side bearing assembly cause the bearing was starting to hum figured the sensor was gone too took the truck for a drive abs still engaging once in a while but seems to only do it when turning left is it possible my drivers side abs sensor is also gone? Also after changing a wheel bearing/sensor are you suppose to unplug your battery and reset the computer?
Old Aug 14, 2013 | 07:38 PM
If the ABS warning light is illuminated while driving, retrieve the DTC's and post them here. If the light is off, check this technical service bulletin, (it also applies to your 99 Jimmy): http://ww2.justanswer.com/uploads/GM...s_bulletin.pdf
Disconnecting the battery will not affect the ABS.
Tinted
Mar 15, 2012 02:56 PM
iamchevyman5
Feb 28, 2011 04:35 PM
stormshadow1
Apr 23, 2009 09:46 AM
Akira
Jan 19, 2007 09:57 AM
Akira
