ABS kicks in under 5 mph
Hey all!
Posting my very first issue with my 2003 2wd standard cab 4.3 manual transmission S10.
When coming to a stop, once I've slowed to less than 5 mph, the ABS is activated on the front drivers side. Research indicates that the ABS sensor is likely the issue. However, I've never dealt with this particular problem before so I wanted to get everyone's input on what brand to use or avoid, as well as any pointers or tips regarding the procedure.
YouTube videos have been somewhat helpful. The job seems pretty straightforward. Just wasn't able to gather much data on brands and so forth.
As always, thanks for your time and attention. 👍😁
Hey all!
Ok so I went ahead and bought new parts for both sides , as they are 17 years old and safety items. Came to my doorstep in under a week for $48.30, thank you Rock Auto.
Everything went smoothly EXCEPT those bolts that hold the wire clip up against the inside of the upper control arm would do nothing but spin and spin. Exactly how the hell you're supposed to get a tool inside there to hold the bolt while you turn the nut is one of those wonderful GM engineering feats only accomplished by a full trained Jedi. Anyhow, all else went well and she functions flawlessly again.
What's that, you ask? What did I do about those damned bolts? Well I'm glad you asked. Pull up a chair and lean in.
First, I had to cut the wire on the old sensor to pull it through the clip. Wouldn't very well come through there with the plug end still attached haha. Then, just ran the new wire through the same route but didn't bother with that clip. Skipped it. But did make sure to mount the plugged in parts back onto the frame where I pulled them from. I probably could have cut the old bolts out or possibly just drilled new holes to mount the new clip but it seemed trivial. With it being mostly hidden inside the control arm I doubt much harm could come to it.
Anyhow thanks for reading my rambling and thanks for your input.
Have a good one!
Have a good one!
Thanks for this, my parents jimmy does the same thing, as well as my blazer. Will do this when I put her back on the road in March. Got a list for the tune up and got a lot of overtime to pull in by then
rexazz2
10-09-2015 01:23 PM
bassson
05-24-2014 03:56 AM
New2Blazer
11-06-2013 08:18 PM
01blaze4door
02-18-2010 08:19 AM
