ABS Line diagram
So I did my searching and all i found was electrical diagrams...
I need a diagram or an overhead picture with some MS Paint labeling of a 1995 ABS controller mounted to the driver side wheel well. Had it on, took it out to do the flip hood, now I want it back in because it don't play nice when pulling behind my Motorhome. My Awesomeness didn't label anything when I took it out, i just cut the lines and then spliced everything together as needed for manual brakes. Now I want to put it back together and I don't remember what line goes in what hole. And if anyone knows what size each brake line is so I can pick up compression fittings to splice back together and male fittings that will screw into the ABS controller that would be great too! It's my only vehicle so I have to pickup parts and then work on it and need everything before I start, its a 30 min drive to local auto store. Either a reply here or an email with the best details I can get would be great! niemannenterprises@gmail.com Thanks Everyone in Advance! 1995 (1/2) S10 Blazer 2 Door 2 WD Automatic 4.3L Vortec (the fun one!) i still have the wiring in good condition, i just had it tucked in the fender instead of cutting it out so everything there will just clip back in place. Just need good details on the brake lines themselves and where they go! |
nobody has a picture or a diagram of their brake lines that I could use???
really? |
I have a 95 vortec 4x4 dont know if its the same but will take some pics mon morning and send sould be close. Jeff
