AC blowing hot air .. were talkin
I found my answer by google but I'd like to hear something from you gentlemen.
just bought my truck I love it.. 1998 LT blazer 95000 miles anyways the AC doesn't work.. it blows hot air whether I have the AC on , Fan on blows hot air in from outside etc.. how is the fixable? i do t k ow if this could make the truck over heat but i read about a Heater valve switch is open behind the glovebox? |
The repair depends on what is causing the condition and the equipment you have.
Do you have auto climate control? When you turn on your A/C, does the compressor run at all? If you jumper the power & ground to the compressor clutch, does it cool? |
Yes the part is called blend door actuator. New about $150. Not easy to get to, but you can get to it by pulling the dash down. It's kinda of square shaped and has a shaft going through it that opens the flapper for switching heat and cold air.
| All times are GMT -5. The time now is 12:32 PM. |
