AC Delco plugs- what's the diff?
Alright guys, so here is my question.
I'm looking at a couple different AC Delco spark plugs, I went to their website and searched all the plugs compatible with my '99 GMC Jimmy. There were a bunch of plugs that all looked the same (except different color metals) and were all listed as "Professional Iridium Plugs". Here are the part numbers: 41-943 41-948 41-950 41-963 41-993 What exactly is the difference between these, if any? Are they just upgraded versions as the numbers rise? I'm looking to buy 6 of one of these part numbers just to give my ride a tune up. Suggestions? |
Probably different heat ranges.
I think the 4.3l engines 2nd gen. calls for platinum or double platinum. I think the iridium is a more controlled spark...I could be wrong, if I am, I stand corrected. |
Differences are the material that the center and ground electrodes are made of. Single Platinum, Double Platinum, Single Iridium, Double Iridium, etc. Originally your '99 Jimmy came with 41-932, the new number is 41-993, (Double Iridium). Platinum doesn't last as long as Iridium.
so would you recommend I put in 41-993 for best performance/life span?
That's top shelf stuff, yes.
so when I go on ebay, i click on the compatibility with my '99 Jimmy SLT and it says its not compatible...(41-993) is this just an error and will it really fit? looks like it would, I just want to make sure.
Gotta be an error. AC Delco 41-932 (double platinum) was original equipment but it was upgraded to AC Delco 41-993 double iridium.
thank you I'll order them now, just wanted to make sure!
| All times are GMT -5. The time now is 12:15 PM. |
