-   -   AC leak...photo attached (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/ac-leak-photo-attached-20434/)
JediKnight2 May 5, 2008 12:23 PM
I just had my accumulator, evaporator and orifice tube replaced because the evaporator went...A week or two ago some of the green dye was in the same location of the photo below...I wiped it up and cleaned it all up to see if it was a leak...today I see this..
http://www.illuminationsfx.com/duckpics/freon.jpg
If you look below the compressor...lots of green dye there...is this a sign of a bad compressor....it does make a racket when I turn on the AC...I can post a vid up with the noise if need be.
swartlkk May 5, 2008 12:36 PM
RE: AC leak...photo attached
Yep, seal on the compressor crapped out on you. Is the system still operational? I guess it is possible that the system was overcharged.
JediKnight2 May 5, 2008 12:39 PM
It is still blowing cold air...so that means a new compressor...cruddo...
rdhack May 5, 2008 01:53 PM
If you are working on this yourself try ackits.com for parts. That's where I gpt parts from when I refurbished two systems recently.
portcqb May 5, 2008 02:55 PM
Yah I have the same compressor and leak if it works it wont for long.
muleman May 25, 2008 06:28 PM
so is the compressor junk and needs replaced or can you put new seals in it??????
JediKnight2 Jul 4, 2008 03:21 PM
Well...it finally went out the other day. I was just trying to milk it until it failed...NOW my question is this...a few months ago I had the accumulator and orifice tube replaced....after that is when the compressor seal went....is it necessary to REPLACE those two things AGAIN...??
95_4door Jul 4, 2008 05:32 PM
Depending where you got them from, they should have came with a warranty. Take them back and have them exchange them out. Make sure you let them know that you are buying a compressor and they will help you out all they can.
