-   -   adding antifreeze (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/adding-antifreeze-25062/)
walkingcrow Nov 23, 2008 10:10 AM
adding antifreeze
I was running straight water in the rad for the last few months after replacing the water pump and heater core.
Its getting colder here so I drained the rad and the overflow jug. I then added 6 quarts dexcoolto the rad and overflow jug. Will the straight antifreeze in the overflow jug transfer and mix with the straight water in the engine block with normal driving? ie will I have a 50 50 mix?
Thanks
WC
WolfPack Nov 23, 2008 10:21 AM
RE: adding antifreeze
Did you drive it alot with just water in the coolant system?
And no it wont mix that fast...that overflow tank is just that...overflow. it only fills and cycles as much as the coolant expands from being hot and if you lose any through leaks or boil off. Why not just drain the system and fill properly?
walkingcrow Nov 23, 2008 10:35 AM
Probably a couple months with just water, maybe 500 miles.
I thought I was doing it the right way, I assumed it wouldcycle through and mix. Maybe I can get a tester from one of the local parts stores? At this point it may be cheaper than buying antifreeze again. I still have a couple quarts so I can drain out the rad and add straight antifreeze if the mixture is low.
WC
swartlkk Nov 23, 2008 02:25 PM
If you put 6 quarts into the radiator, that would make a good mix for the engine/radiator. Wolf is correct that the coolant in the overflow bottle will not be circulated much. I would pull the overflow bottle, drain it, and mix up some 50/50 coolant to fill it back up.
walkingcrow Nov 23, 2008 07:40 PM
I wasn't very clear. I used 6 quarts between the rad and the overflow. I think the overflow may still be 100%dexcool.
Thanks
WC
swartlkk Nov 23, 2008 07:44 PM
Ok.. Gotcha. Well then, you probably are quite under mixed in the engine/radiator then. The cooling system capacity is 11.5 quarts so typically 6 quarts is a good number to put into the radiator after doing a flush. You should drain as much out of the radiator as you can and add everything that you put into the overflow bottle.
