-   -   After Market Fuel Pump Assy. (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/after-market-fuel-pump-assy-60076/)
TrailBlazer 06-14-2011 07:07 PM
Why do the aftermarket fuel pump assy I see have a "new style" electric connector? I would really rather not hack up my harness.
swartlkk 06-14-2011 07:16 PM
The stock harness has been known to have problems with heat and/or corrosion. The new pumps come with a revised connector to fix these known issues. Not every original style connector has these problems, but it is a good idea to use the redesigned connector. Just use some 3M butt connectors or solder & heat shrink the splices. I really like the 3M butt connectors as they have adhesive in the heat shrink tubing on the connector for a nicely sealed connection.
trucktom 06-14-2011 07:20 PM
and put some dielectric grease in the contacts of the plug , keeps the moisture out of it and transfers heat in the case of a weak connection which has always been the issue with the gm trucks
