air bag
where are the air bag sensors..1998 s 10 blazer
RE: air bag
look for the yellow connectors up front... Any reason why you're lookin' for them?
RE: air bag
Yes, the air bag warning is lighting up from time to time..
RE: air bag
Caution:In order to avoid deploying the air bag when troubleshooting the SIR system, use only the equipment specified in this manual and the instructions given in this manual. Failure to use the specified equipment as instructed could cause air bag deployment, personal injury to you or someone else, or unnecessary SIR system repairs.
I would rather get a few $$$ togther and have the pros check into the problem rather than have an airbag go off accidentally while trying to diagnose the problem. There should be 2 sensors up front on thefront frame cross-member, just inside the LH frame rail and just inside the RH frame rail. |
