-   -   Air Conditioning Question (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/air-conditioning-question-92748/)
Jimmer 06-23-2016 06:19 PM
Help
Trying to find out if adding/ top up R12a refridgerent in my 2000 blazer which a 134a will harm anything
.In Canada everything is labeled Do Not Mix Refrigerents.
Has anybody mixed the two
Do not want to dump the system
Just need to add a little as the system is not blowing cold .
Thanx in advance for any responses
Confused
10-78 edac 06-23-2016 07:36 PM
do not mix Refrigerents. 35 yr. HVAC tech
Tajohns34 06-24-2016 06:33 AM
First of all just as 10-78 edac said, do not mix. And second a 2000 should have R134a, unless Canada has different regulations. In the states everything after 1993 had to have R134a.
Jimmer 06-25-2016 04:11 PM
Thanx to all for the input.
roddy 07-07-2016 06:11 PM
Canada is more strict than US. Only AC shop can charge systems. Unlike US where individuals can get licenced to purchase refrigerant.
99% sure your compressor is leaking. HT6's are known 'belly leakers', as they leak between the 4 case parts. Aluminum oxide creeps between O-rings causing leaks.
GM corrected compressor problems for 2003 and up. If you want to go used...
To save money I installed new Sanden SD7 compressor, which is a one piece design, replaced radiator, condenser, fan clutch. This saved a lot of money!
Then took it to AC shop. They replaced Dryer, flushed evaporator and lines. Pressure tested with nitrogen and charged system.
System works great...
TonyZR2 05-30-2017 02:35 PM
roddy
So you are saying it is illegal in Canada to charge your system with 12a, correct?
FMB42 05-30-2017 04:49 PM
Mixing refrigerant types can and will cause serious damage to the system and possibly to yourself and/or others. Had a customer come in with the high-side line blown completely off of the compressor. This customer said that it sounded like a gunshot when it blew (the hood was closed at the time). He said that he and a neighbor added R12a to his 134a system.
blazen_red_4x4 05-30-2017 06:58 PM
Licensed? Huh, in the US any Joe Shmoe can buy R134a at any parts store, heck even WalMart, for less than $10 a can...
R12 is just simply hard to come by and if you're lucky enough to find an AC tech or shop that has some, it cost a pretty penny to refill, and is usually just best to convert to R134a at that point...
Bagherra 05-31-2017 09:20 AM
Not to threadjack, but how much did all this cost? I'm interested in doing the same once I get my girl up and running...
blazen_red_4x4 05-31-2017 11:18 PM
I personally in my driveway replaced my compressor, lines, condenser, dryer, and flushed my evaporator. Was about $350 worth or parts and a few hours work.
Not a project to undertake if you're not mechanically savvy though, which is why an AC tech can charge so much...
