Air Temperature Actuator
Old May 17, 2010 | 08:03 AM
epederson's Avatar
epederson is on a distinguished road
Default Air Temperature Actuator
I have remove the electric air temp. actuator from under the dash. And I was ready to install the new one, but decided to test it before re-installing it. I'm assuming the this actuator should move both directions when turning on the AC and Heater?
Does this some right?
Old May 17, 2010 | 11:22 AM
One of the first things that will happen when you put the actuator in is it will test its limits to program itself. If you plug it in outside the truck, it will not have a door to set its limits on and it may result in a broken temp door or damage to your new actuator.
Old Aug 8, 2010 | 08:33 PM
Fozzy's Avatar
Fozzy is on a distinguished road
I have a buddy trying to replace this actuator now.. he is having problems getting access to the part. How do you get to it other than removing the whole dash board??
Old Aug 8, 2010 | 08:47 PM
Small hands and one of those ratcheting screw driver bit sets.
Old Aug 8, 2010 | 08:53 PM
Fozzy's Avatar
Thanks, I sent all the links I could find to my work email and will show him all I found. Thanks for the quick reply! Hes got tiny hands and is a full time mechanic.. so I hope I can help him for a change.
jdog2pt0
May 29, 2012 08:56 PM
Schrade
Feb 21, 2011 08:18 PM
svd85
May 21, 2010 03:43 PM
markrd
May 8, 2009 01:39 PM
