-   -   AMP wire install sub speaker (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/amp-wire-install-sub-speaker-90695/)
bam_9_9_9 09-10-2015 11:40 PM
alright guys I installed a amp and sub in my blazer and thought I would share it with ya.
its for the 2nd gens but could also work for the 1st gens as well.
bam_9_9_9 09-10-2015 11:52 PM
also I have upgraded to a ad244 alternator which is a simple install in any blazer jimmy and bravada, Sonoma, s10.
I will put up a vid soon... after this.
Tajohns34 09-11-2015 09:24 AM
8 Gauge is pretty good for 1 amp usually. I have 4 gauge run to mine but it is a 5 channel. I also used a rubber grommet to run it through the firewall. But your method is fine also.
Thogert 09-11-2015 03:04 PM
I've got 4ga on both of my amps, one 1KW mono and one 600W 4ch. Overkill, but I don't want to worry about it. Also, 4ga and 0ga wire just looks killer.
LeFlamaBlanca 04-26-2021 12:01 AM
Bro! Thank you!
I sat there scratching my head staring at that firewall that practically every square inch of is covered by SOMETHING! going, Where the hell am I gonna go to get this wire in the cab! And thought well let me do a quick search and found your post! it worked like a charm! That was a life saver mainly because I'm ****ing lazy and didn't wanna have to drill a hole AND because I couldn't spot one place where I could actually drill without removing the hvac housing or anything else. Again, Thank you! Gotta run the ground tomorrow and finish hooking everything up but your post was a real life saver!
Amp Subwoofer install Blazer Jimmy Bravada S10 Sonoma - YouTube
