Another 4WD light flashing problem
Old Jul 8, 2012 | 05:18 PM
  #21
greatwhite's Avatar
greatwhite is on a distinguished road
OK got the cable off doesn't seem bad i"m not sure how easy it should slide. I might add that when the cable was hooked up I could not pull the actuator in by hand, but the vacuum pressure could.
Had to undo it from the actuator as well. I don't see anything wrong with it and the shaft it was attached to seems OK. I can pull the cable easily it's a bit sticky to move back and forth but other then that it's OK. I tried testing the switch, it was hard to tell if I had a good connection if I did then the switch didn't work. But I'm not 100% sure.
I noticed on another thread that when it is connect to the fork I should be able to pull it an engaged it. I didn't try that should I??
Is there anyway to test the switch now that the plate is off. Like I said it was hard to test get the prongs in when it was attached.
Old Jul 9, 2012 | 04:11 PM
  #22
greatwhite's Avatar
Bump.......
Trb
Feb 3, 2015 09:41 PM
Jeremiah Friedel
Feb 20, 2014 07:23 AM
chrishorton74
Jun 2, 2010 09:03 PM
tomas
Dec 3, 2007 04:49 PM
ozracin
Aug 27, 2007 07:35 AM
