Another p0300 problem this one has got me puzzled help!!
Old Sep 25, 2011 | 08:17 AM
97jimmy4x4's Avatar
97jimmy4x4 is on a distinguished road
Default Another p0300 problem this one has got me puzzled help!!
OK so I drive my truck to work ran great all the way there parked in the parking lot idled for a few and shut it off. Came out at lunch went to start my truck and its missing so bad it will barely run and if you get it to run its seems to be maybe 3-4 cyls firing. The code I am getting is an p0300 my favorite lol anyways first thing came to mind was what the hell put a new ac cap and rotor on it so i did no change,new fuel filter, same fuel pressure is at 56 psi. timing on scan tool inset jumping around distributor is tight no play side to side. Drained fuel replaced with new same. Got running hooked vacuum gauge up and makes poor vacuum because its only firing on a few cyls but needle is steady. plugs are new so are wires all ac parts learned the hard way before. had ign module tested good. ohmed out coil within gm specs. I'm thinking maybe spider but not sure. any ideas??
Old Sep 25, 2011 | 09:02 AM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
Did you properly gap the plugs and did the weather change any from the time you went to work to the time you went to lunch. The reason I asked about the plugs was because the book that came with the truck said to gap the plugs at .040 and the parts place said to gap them at .060 and thats a big difference. Oh and the part store is the one you want to go by.
Old Sep 25, 2011 | 10:59 PM
pettyfog's Avatar
Originally Posted by 97jimmy4x4
....o start my truck and its missing so bad it will barely run and if you get it to run its seems to be maybe 3-4 cyls firing. The code I am getting is an p0300 my favorite lol anyways first thing came to mind was what the hell put a new ac cap and rotor on it so i did no change,new fuel filter, same fuel pressure is at 56 psi.>>>> timing on scan tool inset jumping around <<<<<distributor is tight no play side to side. Drained fuel ...
What does that mean? If the timing is 'jumping around', points to either the CKP or.. more likely.. the distributor pickup.
roadkill
May 15, 2010 07:19 PM
89GMCJames
Dec 2, 2009 07:29 AM
taloka
15
Nov 9, 2009 09:18 AM
jman_08
Nov 7, 2008 12:38 PM
kingdog
Aug 25, 2008 03:51 PM
