Another silly question from the old man
Can some enlighten this old man on how to remove the Vanity mirrors on the visors?? I ordered a new set But can't figure out the way to remove the old ones without busting them up. If I can learn to remove the old ones it should make it easy to install the new ones without breaking them. I'm working on a 1998 Blazer LT 4x4.
THANKS. |
Oh, without busting them? Never mind.
I think I removed the whole visor (3 screws), brought it inside, and eventually just pried at it until the front popped off. But now the mirror slides around in the frame so I assume I did something wrong. |
Originally Posted by wyzardd
(Post 512158)
I think I removed the whole visor (3 screws), brought it inside, and eventually just pried at it until the front popped off. But now the mirror slides around in the frame so I assume I did something wrong. Anyone else to help both of us now?????? |
Use a small screwdriver and pry off the light lens.
You'll see two plastic tabs, top and bottom, on each side under where the lens were. Pry these tabs and the mirror frame & glass will come off. Use a bit of vasoline on the new hinges to help keep them from breaking. |
Originally Posted by LRV31
(Post 512168)
You'll see two plastic tabs, top and bottom, on each side under where the lens were. Pry these tabs and the mirror frame & glass will come off. Use a bit of vasoline on the new hinges to help keep them from breaking. Second question is how do the light bulbs come out?? I tried pulling them tried to yurn them I finally broke one. So now I;m stumped again. Thanks |
Glad to help.
When I replaced mine the bulbs were still good so I just left them as they were. |
Both mine on the drivers side are burned out, passenger side is good. Maybe someone has had to change them
Thanks for your help. |
prying my dude... i popped em out and pryed em back in... trust a prybar but use a small flat head lol
| All times are GMT -5. The time now is 08:47 AM. |
