Antifreeze Leaking. Need Help.
So i had just replaced my water pump as antifreeze was leaking from it and then everything was fine for about 1 1/2 months. Then it started to leak off and on and i was always having to refill my antifreeze. All the hoses are fine and there are no cracks in the radiator. When i was driving it the heat gauge stayed the same as what it always is.
Just wondering if anyone has any thoughts?
Thanks
Thanks
You are sure its not the radiator? I found hairline cracks in mine causing leaking on the less visible side. Check the hoses themselves for leaks themselves too for a start, both upper and lower.
craig1319
23
07-06-2018 11:26 PM
Blazer4U
10-24-2008 04:03 AM
