Any idea how to fix this door latch metal?
Old Jun 11, 2012 | 06:01 PM
jimi's Avatar
jimi is on a distinguished road
Default Any idea how to fix this door latch metal?
Here is a picture:
It's basically broken through all around the latch, and only held on by a little metal on the outside and some paint. I can wiggle it easily, and the door doesn't really close well obviously. I'm actually amazed it's still holding on.
Anyone had a latch do this?
Old Jun 11, 2012 | 07:14 PM
NVANZEE's Avatar
it is caused by you door pins and bushings being bad for a LONG time. You will have to pull it off and weld in a piece of steel to fix the striker. You may also need new door hinges as im sure the pins have worn into them or drill the holes and get oversized bushings
Old Jun 11, 2012 | 07:35 PM
Spot on perfect, I agree 100%. If you keep them lubed & replace the pins & bushings at the first sign of wear, that'll never happen.
Old Jun 12, 2012 | 06:27 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Not entirely true. Ive stayed on top of my pins and bushings. Once the cracking starts, it will continue no matter what your pins and bushings look like. The holes in my hinge are still in perfect shape, yet my door latch looks the same. I change them out at any sign of misalignment of door and jamb. I also constantly check my bushings to make sure they aren't cracked.
Old Jun 12, 2012 | 12:02 PM
Misalignment of the door is what gets the process started, worn pins and or bushings, (or an accident) is what causes the misalignment.
ComputerNerdBD
Feb 29, 2012 08:09 PM
blazinloud
24
Oct 1, 2011 05:33 PM
ussexplorer
Aug 10, 2011 12:14 PM
cjh
May 15, 2010 09:06 PM
ESKYMOPACK
14
Mar 27, 2009 09:42 AM
