Any way to evaluate transmissiion cooler?
I have a 98 Blazer LS w/ 75k,and it has developed the dreaded intake manifold leak. I never had a low coolant level before the leak developed, and I don't see too much dex-cool rusty sludge around, and I don't have general overheating. However, I am concerned that the AT could be overheated if the radiator has sludge forming around the transmission cooler. Is there a way to monitor the performance of the radiator to be sure the AT is not being overheated. Anything, such as a scan tool output, or a spot where I could attach thermocouples, or whatever trick somebody knows about to check out the cooling. Thanks.
RE: Any way to evaluate transmissiion cooler?
Why not throw on a n external tranny cooler? They work much better than the stock internal one and are pretty cheap insurance. I put one on the Yukon and the trans has over 200k on it with no problems, towing, hauling, off-roading....
You can stick a thermostat in the cooling fins to check the temp, check with your local autoparts store for the thermostat. However if the engine temp isn't higher then normal, I doubt the tranny temp has gone up.
However the best way to monitor the tranny temp is to install a tranny temp sensor in the tranny pan and put the gauge in the cab of the truck.
Ok, do you know what the correct temperature is for the transmission?
chevyblazer9588
12-07-2011 07:46 PM
bigdaddykane93
03-05-2011 10:13 AM
Chadoo951
25
02-10-2008 11:26 AM
