Automatic transmission oil pan gasket won't fit?
I'm finally doing a fluid change for the automatic transmission in my 2002, 2-door, 4WD Blazer. I order this AC Delco filter and gasket set from RockAuto, and the gasket doesn't line up with the bolt holes. Did I order the wrong part, or did RockAuto mess up?
https://www.rockauto.com/en/moreinfo...84286&jsn=1645 My oil pan is 16 bolts. The gasket is 16-bolts. But they don't line up. https://cimg8.ibsrv.net/gimg/blazerf...c0433065dd.png The filter itself seems to be the same form factor, but it is made of a different material than the original one I pulled out. The original is a black plastic all the way around. The AC Delco replacement I ordered is aluminum on the bottom side. https://cimg4.ibsrv.net/gimg/blazerf...772eab16a4.png https://cimg3.ibsrv.net/gimg/blazerf...0f552597b3.png |
I did a quick search on rock auto. And think the wrong one was ordered.
I put in your info, and I was not able to find the part number that you labeled. Or an acdelco one for that... https://cimg7.ibsrv.net/gimg/blazerf...dc77d72b03.jpg |
Actually yes I did order the wrong one. Turns out mine is considered "deep pan".
| All times are GMT -5. The time now is 07:24 PM. |
