-   -   Bad idle and acceleration, need help. (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/bad-idle-acceleration-need-help-51990/)
matt92 11-26-2010 04:47 PM
This just started happening yesterday.
At first, it was only when i was accelerating, and it would hesitate pretty bad.
But today, It idles horrible, and accelerates even worse.
I had the codes checked, and i got coolant temperature, and secondary air injection.
Do these affect idle? and how hard is it to fix this??
I bought a thermostat too.
01vortec 11-26-2010 06:12 PM
change the coolant temp sensor. secondary air injection will not affect how the motor runs.
matt92 11-26-2010 06:35 PM
alright, wheres it at? and how do i replace it? :D
matt92 11-26-2010 11:47 PM
bbuummpp
webstar1271 11-27-2010 06:12 PM
also try lucas "a real fuel system cleaner. and or "seafoam" it.
swartlkk 11-27-2010 06:56 PM
You know... Instead of uselessly bumping your post you could have tried the nifty search feature... "Coolant+temperature+sensor+location" seems logical... Near the bottom of that search page is this thread:
coolant temperature sensor
:icon_wink:
But what were the codes your received. You may actually want to diagnose the problem before just replacing components.
On your idle issue, a few DIY preventative maintenance items may be in order. Such as cleaning your MAF sensor, throttle body (including the IAC sensor), and EGR valve; much of which is covered in various threads found in the Tech Article (DIY) section.
