Ball Joints
Folks,
As I stated in "Tires and Wheels" I'll be picking up some new rubber for my 95 4x4. (Thanx for the feedback on the rubber too) Before I put any on I need to do my ball joints.. I've read in here most lean towards the Moog brand so I'll be going with these. Couple questions I have... Do I nave to pull the hubs to get my upper and lowers out? Is there any write up (How To) in here on best practices for doing the ball joints like a walk through or something?? While I'm under there and have everything opened up and jacked up (my momma didn't raise no fool I have stands)... I think I might do all the ball joints under there... is there anywhere that I can find a list of all of them so I can order them at the same time as my upper and lowers?? Any special tools I'll need to obtain other than a pickle fork and normal hand tools (I do have an air impact) and I do have a drill to drill the stock rivets out of the uppers.. lowers have already been done so they're bolts. Last but not least... any "Tricks" or "Do's and DON'TS" Thanx folks! |
RE: Ball Joints
there is a real good writeup somewhere on this site about replacing all the joints. just search for ball joints
RE: Ball Joints
ball joint thread found it
RE: Ball Joints
if you are going to rebuild the front you better do the rear also or it will be like driving a heavy boat, I got two blocks from the shop after doing the front and about rolled it in a turn.
I spent about $700on parts at dealer cost. |
