Blazer 4.3 V6 Throttle Body broke & and stuck intake
If I had to guess, which I do, I'd say this was an error made during assembly of the TB, or bad rivet(s). I'd guess the baffle came off relatively clean and got mangled trying to combust itself. Depending on the alloy aluminum melts at a relatively low temperature. It forges at 450°f, a third of the temperature where steel becomes malleable.
But no, it's most certainly not a common failure.
Dear all I have used a Neway Valve Seat Hand Cutter tool and remachined all exhaust valve seats. Since I am driving with propane all valve seats had wear near were the spark plug is.
I also replaced all exhaust valves and tested then by an reverse air leak test.
I took my mighty vac and with a vacumm special plate applied underpressure below from the cylinder head to test test.
So now I putting everything back together an I hope all works out Ok
Thank you all for support.
Greeting
Bob
Greeting
Bob
csteez
03-10-2011 08:25 PM
Parkonahill
Performance & Brainstorming
10-20-2008 05:33 PM
