Blazer actuator
Old Jan 16, 2018 | 12:22 AM
Briggs's Avatar
Briggs is on a distinguished road
Default Blazer actuator
I have a 98 blazer that I replaced the vacuum lines around the motor on. Everything checked out when I did it, all the connector valves move air, and were put on appropriately. The actuator under the battery is now fully depressed all the time with constant suction. I can shift into 4hi and 4lo but in 2wd it seems like it's not disengaged. It's in posi lock 2wd all the time. Please help.
Old Jan 16, 2018 | 01:17 AM
On the 1999 there is am electrically actuated vacuum valve between the front axle engagement vacuum actuator and the vacuum supply. It hangs at on the upper lip of the firewall above the distributor. I've heard of the hoses to these being hooked up backwards causing problems. Is it possible something like that is going on with your system? Perhaps your vacuum valve is not working or the electrical connections to it are bad?
Old Jan 16, 2018 | 04:23 AM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
Since yours is a 98 you need to look at the SPID sticker in the glove box to see if it is a ZN4 extended build. They would have the 99 electric switch on the firewall. All other 98's would not have it. GM must have had a very successful marketing scheme that year and built additional 98's a month into the 99 schedule with all the 99 components.
If you want to double check your hose routing see this:
Old Jan 18, 2018 | 06:26 AM
Strangerock's Avatar
Strangerock is on a distinguished road
I think Christine has the answer and I believe its not a year thing but a 4 button 4x4 thing and on mine the top nipple of that firewall vacuum switch goes to the actuator , the bottom nipple T's off going to the vacuum ball in the fender.
Old Jan 19, 2018 | 05:25 AM
chevyriders's Avatar
I accidentally reversed these on mine once, and it caused the exact problem he is having.- it is likely his issue if he has a 4 button r-case
I believe Strangerock is right, it's a 4 button thing. 3 buttons don't have the valve, 4 buttons do.
Old Jan 20, 2018 | 10:14 AM
Briggs's Avatar
Just an update it's a three button 4x4. All the hoses going to the transfer case are correct. Talked to the local wrench turner and he thinks it's the transfer case switch. He explained that if it is broke or not operating properly it won't switch to the outside air source. Thus causing constant suction but allowing 4x4 to operate. I'll change it out and see what happens.
Old Jan 23, 2018 | 03:11 PM
Briggs's Avatar
The actuator switch on the transfer case was the culprit. It was stuck open leaving the vacuum engaged at all times. Thanks all for the input.
stormshadow1
Jan 4, 2010 11:03 AM
stickemdano
Nov 14, 2009 11:13 AM
markrd
May 8, 2009 01:39 PM
toofancy83
Dec 11, 2008 11:23 AM
shanes
May 5, 2006 01:23 PM
