Blazer Died on Freeway - Bad Alternator?
#22
My blinkers aren't working now, I think it's related to me not having a switch for the hazzards and shoving my key in there to turn on the hazzards. I am going to mess with it today and see if I can get it fixed, otherwise it's hand signals for now lol
#24
Thanks for all your help through this, I hate paying a mechanic to do this type of stuff when it can be done myself and I learn a thing or two about these trucks.
#25
On second thought... this says it fits 98-05 only: Dorman Products - Search Results
If yours looks like this, it might be worth a try, (it just pulls straight up out of the multifunction switch). If not, you'll have to get the entire multifunction switch.
Best to check all of the fuses, in both fuse panels, with the ignition in the RUN position. Without removing the fuses, check both terminals on the top of each fuse with a voltmeter or test light.
#26
#27
Where is the fuse? Would it be for just the hazzards or would it be the fuse for the blinkers? I was worried it was the entire blinker switch which is a $175 part from what I saw.
#28
Well that was the new price from Napa, I ended up fixing it last night though it was just a matter of having the little metal pieces touch the right way so I could get brake lights and blinkers.
I ended up putting a Delphi fuel pump in it because I could not find an AC Delco in stock, from what I read online they're pretty much the same company, is that right?
#30
Sorry to bring this thread back from the dead but I am having another issue related to my initial problem that was posted in this thread.
So I have been driving on the new fuel pump for about a month now, I won't let it drop below 1/3 of a tank just to be safe on the pump but the last week it has been sputtering and slightly misfiring when accelerating from a stop.
I did some searching around on here and every thread seems to point to fuel pressure, should I do another pressure test first or could this be something as simple as a ERG valve needing to be cleaned or new spark plugs or wiring?
I have a "Service Engine Soon" light that just came on while driving home from work today as well, most likely related im going to run the codes today.
