-   -   blazer not gettin up to temp (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/blazer-not-gettin-up-temp-82562/)
Thager 11-06-2013 02:27 PM
my 2000 blazer is not getting up to temp , i flushed the dexcrap out and put in the green antifreeze, i back flushed the heater core and everything else seems to be flowing , could it be a bad t-stat, or water pump.
dirt101 11-06-2013 02:30 PM
I feel the same way about my truck, I just bought it and the guage only goes up to halfway between 100 and the first hash mark. It has me a little worried.
Thager 11-06-2013 02:32 PM
yeah mine barely moves even after running for 15-20 mins, its been getting cold here -20c so i need it to heat up .
swells87 11-06-2013 02:41 PM
I would start by checking your thermostat, they are designed to fail in the "open" state, so if it is bad it will let coolant constantly flow. The other thing to try is hook up a code reader and check your temp. that way, possible the gauge is reading right. and do you have heat coming out after 10 minutes or so of running?
dirt101 11-06-2013 03:36 PM
my heat is not all that hot. I think im going to look into replacing the thermostat. do you need to drain the coolant to do it? if not ill replace it tonight
chris015 11-06-2013 03:44 PM
i bet its the stat,replace it either way if its stuck or not,its less then 10 bucks for the stat and gasket.
Thager 11-06-2013 04:15 PM
yeah i bought a new t-stat today ,here there $13
swells87 11-06-2013 05:01 PM
you dont normally need to drain the coolant to replace the tstat, you may lose some so have a little handy, but you shouldnt lose that much.
dirt101 11-06-2013 11:11 PM
Got my thermostat for $6 and tax, replaced it, and the truck gets right up to temperature now. Thanks guys, heat is like 3x as hot now. I lost about a quart of coolant, so plan for that as well. The install was very easy, just have to make room for the T-stat pipe to pull out of the way.
bassson 11-07-2013 12:03 PM
did you get a thermostat that fails open, they are safer if you spend the extra few bucks on those ones, but you should be fine considering that you just replaced coolant and whatnot
