Blazer Wont Start, Need Help
So, yestarday my 98 LT 4x4 A/T Blazer ran fine when we did our running around. It sat in my garage for about 3-4 hours then we tried to leave again. It turns over, but no sputter, just turns over. The fuel pump is priming when I trun the key on, and I have spark at the engine. If I use starting fluid it will run til it burns that all up, so it seems that there is a fuee problem, also I dont have a fuel pressure guage, but I opened the cap on the fuel rail and after each time of trying to start it, I purge it and gas squirts out, so does this mean anything, is gas getting up to the fuel injectors but not injecting? It looks like all the fuses are good, any help would be greatley apprecaited since this is our only vehilce.
RE: Blazer Wont Start, Need Help
you need to put a pressure gauge on it as these require atleast 50-52lbs to inject fuel. Visible fuel out that port means literally nothing.. Jerry
*UPDATE*, so I went and bought a new fuel filter, the one currentley one it looks old. Swapped it out, still same situaution, so I guess I need to find a Fuel Pressure Tester, or should I just go buy a new fuel pump?
Seems like JP has things covered pretty good... I do not know why you had to PM me.
When you get a fuel pressure tester, run down through the 96+ Fuel System Diagnosis (< click). |
OK, so I will go find a fuel pressure tester, if low pressure is detected, where do I start to replace then, since I just replaced the fuel filter?
Did you read the post that Kyle linked to in his last reply? It gives pretty clear steps of what to do based upon your pressure findings.
*UPDATE RESULTS ARE IN!* Finally found a fuel pressure testerthanks to my local race track owner, and its a good one, Snap-On. Anways here is what I found, with key on slowly rises to 15~20psi , then turning the key off it jumps to 62psi falls to 55psi and slowly, very slowly starts to creep downard. When trying to start jumps to 60psi but falls instantly while cranking. And lastly, while running on starting fluid stays steady at 30psi then jumps to 60psi when the motor dies.
So where do I go from here I dont really understand all the babel in the fuel diagnosis thread and where does my problem fall into that
The way the pressure is jumping around all over the place sounds like maybe the fuel pressure regulator is shot. Do a search and see if the symptoms match.
| All times are GMT -5. The time now is 06:57 PM. |
