Brake Caliper Piston?
Old Jun 3, 2017 | 04:46 PM
mr.vls's Avatar
Default Brake Caliper Piston?
I ordered replacement pistons for a set of rear brakes that came off of a 98 Olds Bravada. The pistons I ordered from Rockauto are CARLSON 7825 for rear disc brakes. The pistons seem to be smaller in diameter than the ones I removed from the calipers. I looked at GMC Jimmy, Chevy Blazer and all the listings for 98+ S-Series on ROCKAUTO and they all call out the same CARLSON P/N of 7825. How close of a fit should pistons fit in the caliper? I thought maybe I ordered the wrong piston but I ordered correctly and the parts I received are the correct P/N. But I do not understand how there could be quite a bit of slop with the fit of the piston in the caliper bore.
Update: I gave up rebuilding junkyard calipers. I am returning the pistons to RockAuto and will buy rebuilt calipers at auto parts store and use the junkyard calipers as core returns.
jimspahr@msn.com
16
Jul 2, 2022 07:46 PM
mr.vls
Feb 12, 2015 08:47 PM
racsan
Aug 11, 2010 12:06 AM
toaks1
Sep 10, 2009 04:26 PM
quinn1991
Tires and Wheels
Dec 28, 2008 02:41 AM
