Brake line leaking, not sure what to actually replace. Pics included.
Old Apr 22, 2012 | 12:34 PM
billfrank85's Avatar
billfrank85 is on a distinguished road
Default Brake line leaking, not sure what to actually replace. Pics included.
I noticed I was leaking something when I came out with a scanner to reset my check engine light...well, I knew it was brake fluid.
Here's the updated pic and video of what is leaking.
VID_20120422_150954.m4v - YouTube
The picture has a red circle around where it is leaking from. Might be hard to see.
Attached Thumbnails Brake line leaking, not sure what to actually replace. Pics included.-img_20120422_151056.jpg
Old Apr 22, 2012 | 12:54 PM
xgiovannix12's Avatar
I never saw rubber brake lines in the frame before
Is this the line that rubs to the caliper ?
Old Apr 22, 2012 | 01:05 PM
Edit: this post is irrelevant now...I updated my original post with the new info.
Old Apr 22, 2012 | 01:18 PM
pettyfog's Avatar
Whatever's leaking.. it aint something with a cable coming out of the end.
Unless someone blasted the other end with penetrant or wd 40.
Old Apr 22, 2012 | 02:20 PM
Alright. I finally rigged a way to see where it's actually leaking from. I'm here by myself, so I had to put a Rhino Ramp in the cab and push it against the brake pedal while I was underneath. It's actually squirting out of what looks like a metal brake line that runs along that frame rail.
Will edit when video is uploaded.
Old Apr 22, 2012 | 02:33 PM
pettyfog's Avatar
Originally Posted by billfrank85
... It's actually squirting out of what looks like a metal brake line that runs along that frame rail.
Why a video? You have to replace that section of line and the way you do that is to find 2 spots where the line is accessible and clean of rust.
- yes, bend the line out away from the frame to work with it.
- if near an existing coupling, replace to it.
Rent or borrow a double flaring tool, and buy the appropriate lines and couplings. Compression fittings wont do.
For instruction on double flare, see google and youtube
Old Apr 22, 2012 | 03:19 PM
Is there just one metal brake line that goes all the way back to the rear axle? I can see the union fitting & screw in the front through the wheel well, but I don't know how it's connected in the back. Feels like there is a clip on the end of the line where it goes to rubber brake hose but not sure...it's pretty corroded up there.
Old Apr 22, 2012 | 03:38 PM
pettyfog's Avatar
Easier to follow the lines from back to front, I think. Start at the rear dust shields and work way forward. While you do one might as well replace any others that have big cluster of rust
LVUSC14
May 24, 2012 01:11 AM
WorkMan1
Jun 3, 2011 11:37 AM
igot10pinitis
Apr 10, 2009 09:38 PM
samurai_24
52
Oct 26, 2007 01:12 AM
rustybeast
Nov 22, 2006 12:19 AM
