brake lines
Old Mar 20, 2013 | 06:18 PM
kcb37's Avatar
kcb37 is on a distinguished road
Was going to add you can bleed just like regualar brakes. However if you have air in the master cly you won't get the air out of the abs.
You will want to bench bleed the mc (can do in the car) The abs you really need to have a dealer use a Tech II.
What this does is while they bleed it (normally) they activate the abs, something you cannot do.
However if you want to do it yourself. Bleed the brakes drive it, hit the brakes hard to activate the abs, bleed them, repete, etc...
Old Jun 5, 2013 | 05:26 PM
Zach_99Blazer's Avatar
Zach_99Blazer is on a distinguished road
Just did my brake job, and the 1/4 fitting on the end of the line doesnt fit into the female end above the rear axle. It is somewhere between 1/4 and 3/16. I'm thinking 5.5mm? I can't seem to find this fitting anywhere
Old Jun 5, 2013 | 06:17 PM
You'll need an adapter, most auto parts stores have them in stock, under $5. The male end, (metric) will fit into the junction and the 1/4" Inverted Flare, (new brake line) will fit into the female end of the adapter.
Old Jun 5, 2013 | 06:20 PM
abig84's Avatar
it should just be u.s. standard thread 1/4 inch line. double check to make sure you didnt get a metric line that has happened to me a few times when ordering 3/16ths line at work, it looks identical to standard but is a hair bigger. should say on the little paper tag that came with the line
there so much stupid stuff that goes wrong, its possible the threads on the rubber line ripped up when you took the old line out. its possible that youre just not getting it lined up just right causing it not to go in.
everytime i do a car/truck at work i always have just a bare fitting to put into the rubber line to confirm the size before i mess with getting the line up there.
if you still have the old line break off the fitting that came out of there and see if that will thread in there, if so you can just cut your new line, remove fitting, install your old fitting then re-flare it if you have the re-flaring tool
Old Jun 6, 2013 | 06:45 AM
Turns out the brake line that i bought from advance was 7/16"-20, and the female end of the center brake hose is 7/16"-24. Got the new adapter and i'm all set.
To think i was gonna get out of a brake job without learning how to flare....
Old Oct 27, 2021 | 11:40 AM
Jaker's Avatar
Jaker is on a distinguished road
Default These Worked For Me
I've done a few brake jobs and I stumbled across these guys online - they shipped my coil quickly and they had a pretty wide variety. https://4lifetimelines.com/ I ended up getting the copper nickel coil kit (LTCC325KIT) https://4lifetimelines.com/products/25-ft-3-16-in-copper-nickel-coil-tubing-kit-brake-fuel-or-transmission-line-fittings-included?_pos=1&_sid=fc5de853c&_ss=r . It was really easy to bend and flare too. Hope this helps!
Jaker
Old Oct 27, 2021 | 02:32 PM
Thanks for the link!
But hopefully after 8 years....... he doesn't need them anymore...
Can help for other tho!
Old Apr 1, 2025 | 01:34 PM
Harry_UK's Avatar
Harry_UK is on a distinguished road
Hi Jaker,
I see that the kit you have used is 3/16 line and fittings - some on this thread are saying our Blazers use 1/4 inch brake line?
The 3/16 was for an 95-05 S10 Blazer?
Thanks,
Mark G.
flipzat
Nov 29, 2009 05:41 PM
bang4dabuck
Feb 28, 2009 04:13 PM
Bigblock396
Nov 1, 2007 02:48 PM
primo
Jul 19, 2007 06:50 PM
