Brake Problem
Brake Problem
So I just got my 99 Jimmy about 3 months ago after having a 95 blazer. Right after I got the Jimmy, I had to replace all the brake lines. After that, it was fine for about 2 months. Now, I'm having very little brake pedal pressure, as in I have to press it down almost to the floor to stop the truck. 9/10 times under heavy braking, the emergency brake light will come on, then go off when I let off the pedal. It did this when the brake lines went when the truck was running out of fluifd. I had it checked out at Midas today, they said everything looks good with the brakes, but they bled the system because the fluid looked pretty dirty, and told me I needed a new front wheel bearing. Any ideas on what could be cuasing this VERY ANNOYING brake problem?
RE: Brake Problem
Stopped, push the brake pedal firmly for a minute and test if it goes down slowly. If do that is the time fror the brake pump. It MUST stay at the same level. Thje light being on/off maybe is related with low fluid level.
RE: Brake Problem
I can't imagine why you had to replace the brake lines - but given that you have, the only things left that can cause a brake problem like this are a faulty master cylinder, a bad power brake booster (possibly an MC leaking into the booster) or a bad/leaky caliper or brake cylinder. A leaky caliper or brake cylinder would be easy to spot, but master cylinders can be tricky.
There is no "brake pump". No such part exists.
It sounds like you're getting air in the brake lines. I'd go back and do a long, careful brake bleeding. If you keep having problems after that, unless you're mechanically adept I'd take it to a shop and have them diagnose it. This is a safety issue and could bite you hard.
RE: Brake Problem
Brake pump = master cyl. Sorry.
RE: Brake Problem
ORIGINAL: pilgrim
RE: Brake Problem
Bleed the front brakes, too, just to be on the safe side...
If the fluid was dirty, like the guy said, it should have been drained as much as possible and replaced.
RE: Brake Problem
Naaaaaaaa. Master cyl or whatever the name is. When you push half the pedal you are pumping and you get better pedal. The fluid is probably passing to the rear of the pump: no looses of fluid but internal leaking. Do my one cent test. THE PEDAL MUST NOT MOVE WHENIS PUSHED DURING A LONG TIME. Air is different as well as spongy hoses. And if you pass the test, well ....I'm wrong and you'll have brakes when you need them.
RE: Brake Problem
ORIGINAL: drperry
RE: Brake Problem
My 99 blazer, after changing the brake fluid did the same thing, I kept bleeding the brakes and after disconecting and reconnecting the battery, I went for a drive in a empty parkinglot, and hit the brakes a few times very hard, seems this all has to do somehow with the anti-lock-brake system, my issue was corrected, hope this helps you out as well.
RE: Brake Problem
Still having the problem. Brakes still work, but I have the jam the pedal down to the floor almost and the brake light still comes on. But if I pump the brake pedal once and then brake it seems normal. what gives?
