-   -   brake question (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/brake-question-81149/)
wild bill 08-18-2013 02:19 PM
brake question
on 98 jimmy had squeal from rt front, checked brakes and inside pad is worn down bad, outside pad has lots left. Could this be a bad caliper?
abig84 08-18-2013 02:31 PM
sometimes the pads rot inside the caliper bracket and get stuck against the rotor and cause it to wear down extremely fast. just seen it the other day on a explorer. 3 pads had like 35% left and one of the inside ones was down to nothing and grinding. had to beat that pad out of the bracket with a hammer where as normally it should just slide out.
wild bill 08-18-2013 03:17 PM
Guess I'll just replace front pads and see how they do
Twip 08-18-2013 04:27 PM
make sure that your caliper pins are well greased. it could be sticking on the pins too. always, always coat them with some fresh grease whenever they are pulled out.
wild bill 08-18-2013 04:37 PM
k, thanks
coolasice 08-18-2013 05:28 PM
^ make sure to use high temp silicone grease, not standard bearing grease
Captain Hook 08-18-2013 05:33 PM
If the inboard pad wears faster than the outboard pad, the caliper piston is not retracting, (binding in the caliper bore). If the outboard pad wears faster, there's a problem with the hardware, (guide pins binding etc).
wild bill 08-18-2013 05:36 PM
Inside pad is wearing faster, can I do anything to fix the caliper or do I need to replace it?
Captain Hook 08-18-2013 06:08 PM
You can rebuild it, or replace it. Remanufactured calipers are available with or without the mounting bracket, get one with the bracket. Usually cost ~$50. Bolt it on, gravity bleed it, then bleed as normal. DO NOT let the master cylinder run dry.
wild bill 08-18-2013 07:11 PM
never rebuilt a caliper before, but money is really tight now and also need rotor turned or replaced
