-   -   Bravada transfer case to Blazer case (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/bravada-transfer-case-blazer-case-83073/)
bensaintonge 12-02-2013 07:52 PM
My brother has a 1997 Bravada with the constant 65/35 split AWD system. The transfer case pops so he took the front driveshaft off. I just found out that that is real bad for those transfer cases. We are going to swap to a Blazer manual transfer case so it will be a good setup (Bravada diff/axle tube setup with a Blazer T-case). We found a 1986 Jimmy with a manual transfer case in a pick n pull yard, WILL THIS WORK?? I will get the transfer case, and floor shifter console piece/lever. I realize we will have to cut the front of his flow through console off but we just need to know if the transfer case will bolt up.
bensaintonge 12-02-2013 08:17 PM
Or would be easier to just get another Bravada T-Case? Only problem is I can't find any Bravadas at the yard, especially 91-97 ones. Will an Astro AWD T-Case work?
rexmburns 12-02-2013 11:04 PM
It will bolt on and work but figuring out the electronics (vss) is the complicated part. I can put up a bit of info about it tomorrow of you'd like!
bensaintonge 12-03-2013 04:49 AM
Yes please!
AndrewO1991 12-03-2013 08:14 AM
If you decide to get another AWD transfer case you just need one with the same speed sensor.
However the manual shift transfer case would be awesome!
