Break light on no rear brakes
Had the plastic by steering colume off to hook up double din that all works fine but have break light on an noticed when backing down drive way I will hit my breaks an only my front breaks lock up an nothing in back for breaks
Were the rear brakes working before? There's nothing in the dash that would make the rear brakes inoperable. They're mechanical, nothing electric
Yes I'm pretty sure they did but I notice I have a 6 pin plug unhooked an can't seem to find where it goes
Originally Posted by Cole Johnson
(Post 704068)
Depending on your options you will have a few connections that may not have a “home” to plug into. If the brake light was not on before the double din radio work I would suspect might have bumped the emergency brake a notch and tripped the light on. If you had accendently unplugged it no light would occur. That said easy check first, look at brake fluid level under hood. Low fluid will give a indicator light. How low your brake pedal sit. WHen the pads wear down a good amount the pedal general sits lower and fluid drops. Lastly, the usual- normally the pads have metal tabs that will rub on rotor making a squeal sound to make the driver aware the pads need replacement soon. So- check your stuff, brakes are a working in good order necessity. |
Originally Posted by cleburne red
(Post 704073)
