broke fuel rollover valve
Hello I have had to replace my fuel pump on my 1999 blazer 4x4 4 dr. I guess when i took the tank down i broke the rollover valve( not sure if that is what it is called)on the front of the tank it is a yellow piece of plastic that a fuel line attaches too and it goes in the tank. Is this repairable? and if it is how do I do it?
thanks
scott
thanks
scott
RE: broke fuel rollover valve
evap vent valve-to the best of my knowledge-non-replaceable.but...I broke one off myself one time and inserted a smaller copper/steel tube inside and 'bridged' the pieces together and epoxied them together and...it's my own personal truck and I'm not sure if it has run the evap test yet..maybe I could force it to run with my tech 2 but haven't the time(it's my own-everyone elses come first)-actually it was originally a customers Jimmy who needed a fuel pump module and I broke it.(the evap vent valve) I bought him a 'good used junkyard' fiberglass tank and put his on mine(tank after 'fixing'). Mine had a bouncy fuel gauge which I figured I'd fix with a GM sending unit and try my epoxy fix on mine. But as I said, haven't ran it much lately to see if the evap test has run-last I looked at monitors, it hadn't.JP
bigdaddykane93
12-16-2010 04:28 PM
