A/C Bypass Serpentine Belt
Old Aug 8, 2013 | 04:19 PM
newguy's Avatar
Hmmm, I went out and bought a bypass pulley nad now I see they make belt w/o ac
Buy Drive-Rite V-Ribbed Belt 870K6 at Advance Auto Parts
Old Oct 29, 2015 | 08:53 AM
Ryan02Stang's Avatar
Ryan02Stang is on a distinguished road
Does anyone know if its possible to just run the belt above to bypass the compressor?
Old Oct 29, 2015 | 09:35 AM
I found the diagram below for with and without AC. Without AC still has a pulley where the AC compressor is it just seems lower.
Attached Thumbnails A/C Bypass Serpentine Belt-dustinfull.gif
Old Sep 11, 2018 | 07:43 AM
bigcountry0307's Avatar
bigcountry0307 is on a distinguished road
Default Ac bypass
Have a 2000 blazer and ac was locked up and ran great with a shorter belt till tensioner pulley blew now on 4th belt in less than a week can figure out why
Old Sep 15, 2018 | 04:31 PM
Mike.308's Avatar
I would expect the a/c clutch that never gets engaged to play and idler wheel role.
Old Sep 15, 2018 | 06:01 PM
odat's Avatar
Without the AC clutch or bypass pulley / or a idler pulley in non AC units it throws the belt angle off and in by doing so increases tension on the belt from the belt Tensioner
Old Sep 15, 2018 | 06:51 PM
2001ZR2's Avatar
I can tell you what happens when a meth head gets creative and just throws a belt on without the bypass pulley. The power steering pump takes the abuse and the bearing wears then the belt starts to be thrown off as soon as the truck starts.
It can be done for a short time but term it's a really bad idea. The real trick is getting the right bolt and the washer that holds the pulley and bearing in position.
I got one at pick n pull for a couple of bucks which included the pulley as the idler pulley would work also.
Old Sep 16, 2018 | 03:05 AM
Mike.308's Avatar
For me, permanently disengaged a/c clutch is equal to an idler wheel. Why are You reinventing the wheel here?
EDIT: Oh crap, I haven't check the thread post dates and seems I am "out of date" with the discussion Sorry...
Toby Hanson
Jun 5, 2016 07:07 PM
sinbig
Mar 31, 2013 04:29 PM
Stephen Uhlenkamp
Mar 19, 2012 10:28 AM
racsan
Apr 24, 2011 07:38 AM
Blazer_boy
May 18, 2009 10:50 AM
