A/C Clutch
I have 2 questions
1) I need to change the clutch on my A/C compressor, I cannot get the tool for holding the clutch so that I can get the nut off that holds it. is there another way to get this done? 2) my manual does not show it but I understand I need to space an area where the clutch ingages, but I do not know how much space is needed ?? thanks for any help |
RE: A/C Clutch
I have no idea how you can even remove the compressor clutch without special tools.
I can't find specs for the gap on the plate, but I think it's about .020" Sorry I can't help. |
RE: A/C Clutch
If you are replacing the clutch with a new one, then any means necessary to lock the clutch and get the nut off is available and that includes means that may damage what you are replacing.
I believe I have always used an impact gun to get things apart. The nut shouldn't be all that tight. On reassembly, I have always installed the belt then locked the clutch by applying power to it then tighten with a rachet. |
| All times are GMT -5. The time now is 07:41 AM. |
