A/C Clutch, metal to metal sound
I've had issues with the A/C Clutch on other vehicles and on the Blazer, the clutch is making a metal-to-metal scraping noise as if it's rubbing on the compressor. I'm just wondering, since I live up north whether or not it's from not using it in the winter, and can anything be done to lubricate it so it won't make the noise????
You can remove the outer drive half and put shims on the end of the shaft to adjust it out. You want to be careful though as you may cause it to not engage if you put too many in there.
Your A/C does cycle during the winter time to remove moisture from the air inside the truck.
Thanks again Kyle, and thank you for fixing my login!!!
Is there a reason it happens to so many A/C clutches?? I work in the Automotive business, in sales, and have seen this issue on all vehicles.
I know if I were to bring it to a dealership, they'd replace it, but is it a fix or a bandaid??
Also, I do have access to pullers and air tools, is this something rather simple by pulling out the A/C compressor??
Thanks again!
Thanks again!
You do not even have to remove the A/C compressor. Just remove the bolt that holds the outer portion of the clutch onto the end of the shaft and pull it off. It is relatively easy to remove. You may have to squirt some WD40 or equivalent into the hole where the bolt threads in to loosen things up, but you should not need a puller. A puller may break things actually.
The outer portion of this section is isolated by rubber. When the clutch activates, the electromagnet pulls this section into the pulley, engaging the clutch. Over time, the outer section may relax and get closer to the pulley and contact it, causing a squeak.
Shims are not used on Blazers- the clutch is a press fit- there is no bolt or nut on the end--You need to "borrow the tool" from autozone to pull the clutch driver out to a gap of .020"
I happen to know all this because I work in the factory that builds these compressors- and others....and I take them apart everyday....
Really... Damn, yup, you are exactly right... I must have been thinking of the earlier compressors... They are all that I had in front of me to look at. Sorry for the misinformation.
Well, once you get the proper tool, it should be fairly easy to do.
