a/c compressor
hi,
last year i went to get my a/c refilled and the guy told me my compressor isnt compressing anymore. he did a leak test for about 20min, then filled the system with freon(it was empty and did not leak, weird...) once it was done, i turned the a/c on but only had hot air comming out. we didnt went further, he said you need a compressor and took back his refregerent and only charged me 20$ for the time. at that time, the compressor turned on and the clutch was cycling when i put the a/c on that was before i knew about blazerforum.com and all the help that can be found here. now, when i put the a/c on, nothing happens, the light inside is orange but the clutch doesnt kick on. yesturday i did the test with the jumper wire on the low pressure side, and the compressor turned on. i guess this is because im low on refregerent, but how/what are the next steps in troubleshooting my problem ? i also removed the glove box and all vaccum are working right. sorry for the log post, i wanted to make sure you have the same info as me ! thanks ! Anthony |
yeah there is a low pressure switch usually on the evaporator/dryer so if theres no freon the compressor wont go on. if it was full and the compressor was running then it possible you just need a new compressor
''if it was full and the compressor was running then it possible you just need a new compressor ''
yeah but how can i confirm my compressor is dead ? and if i end up changing the compressor, i should change the evaporator and orifice tube ? thats it ? |
When the system is full of coolant and the compressor is running, one of your A/C lines near the accumulator should be really cold. If not, then the compressor is bad. If you do have a cold line, there are other problems. A search on here will tell you the likely cause.
| All times are GMT -5. The time now is 02:48 PM. |
