a/c condensor
Old Mar 23, 2009 | 09:30 AM
2doorblazer's Avatar
2doorblazer is on a distinguished road
Default a/c condensor
Hello all i am new here. I have a 1998 2 door blazer an my a/c condenser needs to b replaced an i am not sure how to do that . Do i have to take the radiator out an it comes out that way .Or do i take the grill out. I will b doing this in the next week. i want to get it done b4 it gets hot so my kids r cool ! thanks 4 any help thanks 2doorblazer
Old Mar 23, 2009 | 10:29 AM
Blazin1's Avatar
Blazin1 is an unknown quantity at this point
Good Luck!!! If I remember correctly, you're gonna have too remove the whole pass. side fender and all that good stuff thats in the way just to get to it! I had to remove the whole Blower Motor Housing and from that point it seemed like the easiest way to replace the condenserit self.
Old Mar 23, 2009 | 10:50 AM
You should not have to remove the fender. The condenser is in front of the radiator. If you were talking about the evaporator (what is in the HVAC housing), then yes, removing the fender would make it easier.
As far as removing the condenser, I do not believe that you have to remove the radiator. I would pop the grill out and have a look at how it is mounted. I think it is between the radiator and the core support so you will definitely have to remove the upper radiator shroud/support.
Old Mar 23, 2009 | 10:56 AM
ok thanks i will look at it after i take the grill off an go from there thanks 4 ur help
alno1995
Jul 1, 2012 06:54 PM
benniekong
Sep 24, 2010 12:20 AM
