A/C question
A/C question
Hey guys. Something is going on with the AC in the truck. With the AC on and at the engine at idle it feels like the compressor will kick off and on momentarily. You can just feel it start to drag the engine down then it seems to let go. The truck always puts out cold air and doesn't have any problems when driving except periodically while idling. We checked the high and low side with gauges and it was fine. My friend suggested that the low pressure switch may be going bad. I couldn't really find anything suggesting signs/symptoms of a bad LP so any help would be appreciated. Thanks
Uneven idle with A/C on
If the pressures are OK and the outside temp is 'moderate' (not too hot), it's normal for the compressor to cut in and out. The engine speed should be maintained about constant by the computer and the Idle Air Compensator Valve (IAC). If the IAC valve is sticking, the idle will be erratic, especially when the A/C is on.
Search for how to clean the IAC for your year.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
Last edited by swartlkk; 06-03-2010 at 12:04 PM. Reason: **Combining Consective Posts** - Please use multiquote feature to quote multiple people at once.
Do you mean engine temp or outside temp? Engine rarely gets over 200. It has 2 electric fans on it. Outside temps are usually in the mid 90's here in FL. Almost the only time I notice it is when I'm picking the kids up from school because it sits and idles for 15 or 20 minutes while I'm sitting in line.
Ok- something else it started doing is once the RPM's get a little over 2000 or so it stops blowing air- would that also point to the high pressure switch? Once the RPM's come down it blows cold air again. Does it have any kind of WOT sensor that shuts it off maybe kicking in too early?
Initially my AC wasn't working properly because the air gap was wrong. That was fixed and everything was fine for a few months. Then it started doing all this. I left it idling in gear today for about 20 minutes with the AC on- shaking wires and what not to see if anything seemed to be shorting out but couldn't find anything. I noticed that the clutch never disengaged. Is it supposed to? Also the IAC and TPS sensors are new.
Depending on the outside temp and humidity, it would seem normal for the compressor to stay engaged while idling. The only way to really check this properly is to hook up some good gauges to the hi and low ports and see what the numbers are.
