-   -   Camshaft removal (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/camshaft-removal-78823/)
Klturi421 04-23-2013 09:36 PM
Camshaft removal
So I am kind of in a bind now. I'm in the middle of rebuilding my 4.3L when suddenly a wild star bolt appears that has been stripped. Now I am stuck with the camshaft in place and can't remove it.
Any tips on removing the stripped star bolt?
AndrewO1991 04-24-2013 08:19 AM
special bolt extractor sockets are sold at most parts stores. Or find a socket slightly too small and call it sacrificial and hammer it on the bolt.
Klturi421 04-24-2013 08:45 AM
I would love to do that except the bolt that I need is flush in the block and to top it off its a star head.
I was thinking about taking it to a machine shop to see if they can remove it.
Any other options I might be able to explore at home?
04-24-2013 04:24 PM
Can you post a pic?
1sttimejimmyowner 04-24-2013 04:43 PM
Is it one of the bolts on the cam retaner?You should be able to get it with a speacility stripped bolt socket.
Klturi421 04-24-2013 05:29 PM
2 Attachment(s)
It is on the cam retainer.
Edit:
I said retainer but I believe that I am mistaken. Its that outer ring that just has the two bolts. The one on the left is the one that has been stripped.
Edit Again:
Looks Like its both a retainer or a thrust plate, just depends on who is writing about it.
The pic is attached for the stripped one. I have not yet attempted the unstripped bolt as I don't want to damage it.
Twip 04-24-2013 06:38 PM
1 Attachment(s)
drill it out with an easy out kit. they are reverse rotation drill bits and extractors. thats one thing that you can do.
the other would be to buy/use a regular 3/8" drive allen socket and hammer it in there. this one has worked more than once for me. this is what im talking about. https://blazerforum.com/forum/attach...ine=1366846726
i think that you should be able to get another one at the dealer or a hardware store. good luck.
1sttimejimmyowner 04-25-2013 08:48 AM
X 2 twip
BRYAN0010 10-02-2017 04:51 AM
I'm in the process of rebuilding the engine in my 98 Blazer with a 4.3 and the same bolt stripped on me. I've tried forcing an allen wrench into it with out any success. Ironically, the other bolt came right out.
chevyriders 10-02-2017 11:16 AM
If you have access to a welder, weld a nut to it. I believe I had to do it to one of mine.
