Car not accelerate smoothly!!!
Hi everybody
Because of Covid-13 I don't use my car for long time I use my dad car because I don't found park near house in these days but today I use my 00 Jimmy to go junkyard and I notice that when the car accelerate it slow down very fast after I remove my foot from accelerator pedal I feel like there is some resist that let my car act like that but I don't know what is this thing.
Anyone have this problem before if yes from where I should start to check?
thank you
thank you
No, but I have ABS and Brake light in instrument cluster and parking brake not work from the day I brought this car until now and I don't fix them.
thank you
thank you
Does it feel or sound like a stuck caliper? Can jack up each tire and try to turn them while on jacks and in neutral.
Always make sure vehicle can't fall off jacks by giving it a nudge before going under.
It sounds like the calipers are sticking. If your able to pull the brake apart, you should be able to push the piston back in by hand, or with pliers. If you can't or its extremely hard to, then I would suggest looking into swapping out the caliper.
If the caliper is bad
thank you
