-   -   Cat Rattle? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/cat-rattle-78675/)
kf7lcw Apr 17, 2013 01:56 PM
Cat Rattle?
Hi All-
I seem to be having the classic symptoms of the cat breaking up. A rattling noise at low speeds or when stopped in gear. Sounds like its coming from right where the exhaust is. Lately I've been noticing a lack of power especially when climbing hills and the like. I don't know any good muffler shops so I am looking at getting a direct-fit cat off ebay. Does anybody have any experience with these? Also I was planning on replacing the muffler with a cherrybomb turbo, does anybody have any suggestions on that?
50lb_cat Apr 17, 2013 03:10 PM
If the bolts come out easily, its an easy job. Might require some heat to get them loose. Be sure to get the gaskets. I have no experience with the turbo muffler, i used flowmaster and love it.
kf7lcw Apr 17, 2013 10:26 PM
I'm thinking about getting a weld-in cat and just welding up the system. Doesn't look too bad. I found a cat on ebay for 52 bucks shipped to my front door. I think I can do that and the turbo for around 100 bucks (granted I know how to weld)
50lb_cat Apr 18, 2013 12:36 AM
Yeah, if you can weld its a lot easier, just cut and weld. If you have a problem with the downstream o2 sensor you can raise it out of the stream with some spark plug non foulers. I had to do that with my hi flow.
