Changing rear differential fluid
I have 80k miles on my 2000 2dr Automatic 4x4 and want to change the rear diff fluid myself. I found some good how-to's on here but have some questions.
What is the correct gear oil to use and how much? What is the best RTV sealant to use? I have read that you cannot use RTV sealant if you use synthetic because it will leak. Is this true? Does anyone have any tips or things I should look out for when doing this? Thanks |
RE: Changing rear differential fluid
The answer that was provided here wasn't good enough?
Please do not post the same question repeatedly. |
