Check engine light flashes at highway speeds. Have run out of ideas. Help please.
Old Feb 6, 2010 | 09:20 PM
  #41
Have you tried running a different brand of fuel or jumping up to high octane for a few tanks to see if it impacts the misfire?
Basically, what I am thinking of here is the possibility that there is some carbon deposits in those cylinders that are causing pre-ignition.
Old Feb 6, 2010 | 09:23 PM
  #42
tazz9690's Avatar
tazz9690 is on a distinguished road
I have used Arco and Circle K.
I also use Premium.
The thing is though, when I hooked up the scanner, 3 misfired a bit more than cylinder 6 at idle, but once I revved it up, they misfired nearly identical. Would carbon build up cause misfires at nearly identical rates at higher RPM's and highway speed?
Old Feb 6, 2010 | 09:33 PM
  #43
Have you maybe tried running regular? I'm just tossing out some ideas on things that may impact the condition that are easily changed.
Old Feb 6, 2010 | 09:37 PM
  #44
tazz9690's Avatar
Oh yeah, I used regular at first, then when I did the tune up and I changed out the injectors, I switched to premium.
If I can get access to the bore scope and there is excessive carbon build up, how would I go about fixing that problem? I am open to any suggestions short of buying a new engine or tearing apart this one, though I don't think there are many options left with all that I have done.
Old Feb 6, 2010 | 09:39 PM
  #45
If there is excessive carbon buildup, a few seafoam treatments may loosen it up and blow it out the tail pipe.
Old Feb 6, 2010 | 09:41 PM
  #46
tazz9690's Avatar
That simple? Gotta love seafoam. I personally have never used it, but have heard good things.
By a few treatments, what exactly do you mean? I wanna make sure I do it right if I do end up having to do that.
Old Feb 6, 2010 | 09:45 PM
  #47
One might not clean it up properly if there is heavy buildup.
Old Feb 6, 2010 | 09:46 PM
  #48
tazz9690's Avatar
Okay, how long should I wait before I do another one? If it doesn't fix it, right then and there after I take it for a drive? Or should I wait like a day, or a week and drive it until then?
Old Feb 6, 2010 | 09:49 PM
  #49
I would wait a day or so, but not too long. You should change the oil after you are finally done.
Old Feb 6, 2010 | 09:53 PM
  #50
tazz9690's Avatar
Great thanks Kyle. You have been a great help with pointing out something that didn't even cross my mind. I will report back sometime during the week with what I find.
Keeping my fingers crossed.
