Go Back  Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > General Tech Help > 2nd Generation S-series (1995-2005) Tech
Reload this Page >
Check engine light flashes at highway speeds. Have run out of ideas. Help please.
Community
Search
Old 02-06-2010, 09:20 PM
Have you tried running a different brand of fuel or jumping up to high octane for a few tanks to see if it impacts the misfire?
Basically, what I am thinking of here is the possibility that there is some carbon deposits in those cylinders that are causing pre-ignition.
  #42
Old 02-06-2010, 09:23 PM
tazz9690 is on a distinguished road
I have used Arco and Circle K.
I also use Premium.
The thing is though, when I hooked up the scanner, 3 misfired a bit more than cylinder 6 at idle, but once I revved it up, they misfired nearly identical. Would carbon build up cause misfires at nearly identical rates at higher RPM's and highway speed?
  #43
Old 02-06-2010, 09:33 PM
Have you maybe tried running regular? I'm just tossing out some ideas on things that may impact the condition that are easily changed.
  #44
Old 02-06-2010, 09:37 PM
Oh yeah, I used regular at first, then when I did the tune up and I changed out the injectors, I switched to premium.
If I can get access to the bore scope and there is excessive carbon build up, how would I go about fixing that problem? I am open to any suggestions short of buying a new engine or tearing apart this one, though I don't think there are many options left with all that I have done.
  #45
Old 02-06-2010, 09:39 PM
If there is excessive carbon buildup, a few seafoam treatments may loosen it up and blow it out the tail pipe.
  #46
Old 02-06-2010, 09:41 PM
That simple? Gotta love seafoam. I personally have never used it, but have heard good things.
By a few treatments, what exactly do you mean? I wanna make sure I do it right if I do end up having to do that.
  #47
Old 02-06-2010, 09:45 PM
One might not clean it up properly if there is heavy buildup.
  #48
Old 02-06-2010, 09:46 PM
Okay, how long should I wait before I do another one? If it doesn't fix it, right then and there after I take it for a drive? Or should I wait like a day, or a week and drive it until then?
  #49
Old 02-06-2010, 09:49 PM
I would wait a day or so, but not too long. You should change the oil after you are finally done.
  #50
Old 02-06-2010, 09:53 PM
Great thanks Kyle. You have been a great help with pointing out something that didn't even cross my mind. I will report back sometime during the week with what I find.
Keeping my fingers crossed.
Quick Reply: Check engine light flashes at highway speeds. Have run out of ideas. Help please.
